flak monkey
| posted on 8/5/08 at 08:38 PM |
Coil supressor?
I am getting some major interference on my RPM signal to the dash/rev limiter (also had it on the old one too) which is causing the rev limiter to cut
in way too early most of the time and also messes up my shift lights.
Simple question really, should I have a supressor across my coil? If so anyone know what capacitance they are so I can get one?
Or could it be something else playing it up? All the connections have been checked and are good.
Sera
http://www.motosera.com
tks
| posted on 8/5/08 at 08:44 PM |
you could try a shielded wire...
for the coil pickup...
and ground it only at one side...
also make sure your coil is grounded good to... (don't isolated from the chasis)
Tks
The above comments are always meant to be from the above persons perspective.
graememk
| posted on 8/5/08 at 08:46 PM |
i had this david with my megasquirt, it kept restarting every time i gave it loud peddle.
supressor on the ford coil solved the probs
big_wasa
| posted on 8/5/08 at 09:06 PM |
standard ford item is 20 uF on the zetec coil packs.
flak monkey
| posted on 9/5/08 at 08:14 AM |
Got a ford part number? Failing that I'll go and annoy the ford techy guys again and make them hunt through their EPC!
Sera
graememk
| posted on 9/5/08 at 10:45 AM |
no mate i havent i got it from big_wasa
