charlierevell
| posted on 19/5/08 at 08:20 AM |
2L Pinto not pulling at high speeds??
Hi all,
A mate has a Dax rush with a 2L Pinto on twin 40's, just come off the rollers a few hundered miles ago ( sept/nov last year)
When pushing on in 5th gear 85-90mph (private roads obviously) it get up to 90 odd ok. If you back off slightly say down to 75/80 it wont accelerate
properly again, it starts to kinda choke and splutter running a little rough.
Come back down to 50 and it will accelerate all the way thru again.
Any ideas?
Tango orange is an 'IN' colour!!
jollygreengiant
| posted on 19/5/08 at 11:11 AM |
dirty jets
carbs out of balance
britishtrident
| posted on 19/5/08 at 11:28 AM |
fuel flow rate
MKMike
| posted on 19/5/08 at 03:12 PM |
Dirt/water in the carbs or Tank breather blocked
MikeRJ
| posted on 19/5/08 at 05:53 PM |
quote: Originally posted by britishtrident
fuel flow rate
I agree, sounds like it's not getting enough fuel. Either the pump isn't up to the job or there is a restriction somewhere e.g. filter or
kinked pipe.
DarrenW
| posted on 20/5/08 at 12:43 PM |
Ive had similar problem before. In line filter wa almost blocked. Some swarfe from drilling tank to fit fuel level sender had found its way down the
lines. Changed sender and all was well again.
Happened most on long inclines at higher engine speeds.
I went through the filters on Halfords shelves to find their largest inline.
