designer
| posted on 1/6/08 at 10:48 AM |
Focus engine/trans
Has anybody got the physical dimensions of the Ford Focus engine/trans?
mr henderson
| posted on 1/6/08 at 10:54 AM |
I doubt anyone is going to be able to give you that information, due to any power unit being such an awkward shape to measure. You would probably be
better to ask specific questions such as how far forward of the wheel centreline would the rear cockpit bulkhead need to be to clear the exhaust
manifold?
I don't know the answer to that particular question either, I'm afraid. There's just no substitute for getting under the bonnet of a
friendly neighbour's car with a tape measure.
BTW I've been all through this when I was going to use a Mondeo as a donor.
John
designer
| posted on 2/6/08 at 06:48 AM |
Yes, that's the right idea.
BUT, the French buy french cars, Peugeot, Renault, Citroen, and I have never seen a french registered Focus!!
Macbeast
| posted on 2/6/08 at 06:54 AM |
If you get specific about what dimensions you want I could have a measure on mine
designer
| posted on 2/6/08 at 08:21 AM |
Many thanks.
Just want to know the overall width for fitting in an old chassis I have in the shed, which is 26 inch wide.
Don't mind a little bit sticking out such as the clutch housing.
iank
| posted on 2/6/08 at 11:03 AM |
There is a dimensioned outline of, I think the Zetec SE here.
http://www.fordpowerproducts.com/FordPowerProducts/pdf/ZSG_Range_Leaflet_4_2003.pdf
There is a regular Zetec dimensioned drawing here.
http://www.locost7.info/files/engine/zetec1.jpg
Sorry haven't seen gearbox drawings anywhere.
Anonymous
Macbeast
| posted on 3/6/08 at 05:17 AM |
My Focus 16V Zetec measures approximately:-
55 cm wide
60 cm long with gearbox projecting a further 30 cms
65 cms high
Hope this helps.
designer
| posted on 3/6/08 at 06:48 AM |
Many thanks
