Author: Subject: UPVC Coolant Pipes
thebutler
posted on 14/12/03 at 06:18 PM Reply With Quote
UPVC Coolant Pipes
Hi,
Does anybody know if it's OK use UPVC piping in the coolant circuit. For example to join two pieces of rubber hose togther?
By UVPC I mean the stuff you get in places like B&Q for plumbing.
Any advice appreciated.
Jon Ison
posted on 14/12/03 at 06:22 PM Reply With Quote
seen it used, but i havent risked it myself, the copper fittings from plumb center do a good job, i used one with a smaller dia "T" to run a line to the expansion bottle from my btm hose, still going strong.
brianm
posted on 14/12/03 at 07:58 PM Reply With Quote
Not sure whether it is suitable or not, (tend to think it would soften to much), but the waste pipes you buy in B&Q are probably made from ABS. Marley make waste pipe in both ABS and uPVC, uPVC being suitable for outside use, but ABS must be protected from sunlight.
steve m
posted on 14/12/03 at 10:54 PM Reply With Quote
I think some light reading on Hicosts accident re hot water, would put anyone off using any thing but the proper items
My cooling system is made up with a multitude of Items, and all of them are/were designed for a car's hot water !!!
FYI, Hicosts car has been built to a very high standard, and James is not someone who "cuts corners", yet his accident nearly cost him his life, I believe that a metal water pipe fractured and filled the cockpit with steam/hot water
The B&Q plastic tube may well be ok for hot water, but is it designed for hot water under pressure ????
Jon Ison
posted on 14/12/03 at 11:14 PM Reply With Quote
dint think of that, very valid points.
thebutler
posted on 15/12/03 at 10:23 AM Reply With Quote
Thanks for the advice. I suppoese it doesn't do to cut corners.
The next obivous queston is where I can get some suitable hose joiners (32mm OD) at a reasonable price. Demon tweeks do them for £8 each!
posted on 15/12/03 at 10:34 AM Reply With Quote
was it northy who posted a link a while ago for a place that had bucket fulls of different joiners and tees?
Northy
posted on 15/12/03 at 06:10 PM Reply With Quote
Yeap, but all plastic
I got some 32mm ones from Demon Peads
Graham
stephen_gusterson
posted on 15/12/03 at 07:18 PM Reply With Quote
i thought a piccy showed that hicosts accident was a hose that blew off its fitting......
atb
steve
malcolmstoddart
posted on 15/12/03 at 08:05 PM Reply With Quote
UPVC Coolant Pipes
You could.. join the hoses with copper pipe and put beads on either end like below...
http://www.locostbuilders.co.uk/viewthread.php?tid=9080
Hellfire
posted on 15/12/03 at 09:07 PM Reply With Quote
Very reasonable prices...
Try visiting the following site - they are great lads and prices are extremely reasonable.
Click HERE to go there...
Good hunting!
posted on 15/12/03 at 10:27 PM Reply With Quote
28mm Yorkshire fittings available from plumbing suppliers with the solder ring fitting have a lip for the jubilee clip to grip behind and are reasonably priced. I've used them to extend my bottom hose.
yours, Pete.
thebutler
posted on 16/12/03 at 01:11 AM Reply With Quote
Thanks for all the reply's chaps.
Having read back over what happened to Hicost, I've decided to go with the safest(?) route and order some joiners from DT - expensive, but at least they'll look nice...
tadltd
posted on 16/12/03 at 09:45 AM Reply With Quote
Just in caseyou haven't ordered yet, have you tried Merlin Motorsport? They do a wide range of ally hose joiners in different diameters and lengths which I THINK are cheaper than Demon Tweeks.
I think they're on the web, not sure of the address tho'... Anyone?
Steve.
(edited because I can't spell!)
[Edited on 16/12/03 by tadltd]
posted on 16/12/03 at 09:50 AM Reply With Quote
main site:
http://www.merlinmotorsport.co.uk/
any thoughts on the vulcoflex hoses?
thebutler
posted on 16/12/03 at 01:06 PM Reply With Quote
I did try Merlin, but they were more expensive (10p) Also they didn't have a picture, and it's nice to see what you're getting!
[Edited on 16/12/03 by thebutler]
