Author: Subject: 1300 Cross Flow Fuel System
Michael
posted on 27/7/08 at 08:14 PM Reply With Quote
Calling for some advise by anyone using the Cross Flow Engine.
Is the mechanical fuel pump strong enough to get the fuel from tank to Carb or does it need assistance??
dave-69isit
posted on 27/7/08 at 08:17 PM Reply With Quote
what carbs u running
dave-69isit
posted on 27/7/08 at 08:18 PM Reply With Quote
what carbs u running manual pumps fine for standerd setups
Michael
posted on 27/7/08 at 08:26 PM Reply With Quote
Standard Downdraft Solex.
stevebubs
posted on 27/7/08 at 09:54 PM Reply With Quote
I think, assuming it's in OK condition, it should be fine for that but would defo struggle with twin webers.
stevebubs
Ran mine with DGAV and mechanical pump without probs, BTW
ian.lucas
posted on 28/7/08 at 08:58 AM Reply With Quote
I had an issue with mine, it was found to the fuel tank breather hole had been blocked off, after running the car for about 5 miles it would start to cut out when slowing down for corners (idle speed) pump could not pull the fuel from the tank because of the vacuume build up in tank
David Jenkins
posted on 28/7/08 at 09:00 AM Reply With Quote
That would cause problems with any pump!
steve m
posted on 28/7/08 at 09:07 AM Reply With Quote
"I think, assuming it's in OK condition, it should be fine for that but would defo struggle with twin webers."
I ran my twin 40 webers with a mechanial pump, with a stage 3 xflow
no problems there
Marcus
posted on 28/7/08 at 11:39 AM Reply With Quote
As Steve says, there's plenty there for twin 40s on a 1300 providing the diaphragm is in good nick. Dirt cheap to replace though.
Marcus
Because kits are for girls!!
Michael
posted on 28/7/08 at 08:55 PM Reply With Quote
Oh thank god for that.
At least something is going ok lately.
