bassett
| posted on 17/9/08 at 11:49 AM |
Can I use fuel/oil hose for water?
Hi, Basically as the topic suggests can i use oil/fuel hose for the water system as i can not find 6mm water hose anywhere as its off an R1 so has
very small hose.
tegwin
| posted on 17/9/08 at 11:59 AM |
Thats exactly what I did for my bike engine...
Cant see it being much of an issue given that fuel hose is chemical resistant and can withstand that sort of pressure...
Just dont try and do it the other way round
www.verticalhorizonsmedia.tv
bassett
| posted on 17/9/08 at 12:07 PM |
Thanks for the speedy reply, was thinking also if anything it would be better as surely oil will be around same temp, always good to double check
though.
Adam
Howlor
| posted on 17/9/08 at 12:20 PM |
I used something like this if it helps.
Dock of the Bay
bassett
| posted on 17/9/08 at 12:25 PM |
I had thought about that but if i bought that its going to be 5-6 times more expensive and id want to change the rest of the hoses. Might change them
to all black silicon sometime in the future once its running and the wallets recovered
| posted on 17/9/08 at 03:41 PM |
I've run 8mm fuel hose to / from the header tank without a problem. Not sure what Mr SVA thought about it but he didn't seem particularly
bothered by it!!!
bassett
| posted on 17/9/08 at 04:35 PM |
Good to hear Ben, hope it will get through as i think they are only really concerned with the fuel hose (ours are all marked as)
mad4x4
| posted on 17/9/08 at 05:10 PM |
Tell you what a bit of fuel hose from the header tank will look more proffessional than garden hose or clear hose... Shouldn't be a prob.
Scot's do it better in Kilts.
Danozeman
| posted on 17/9/08 at 06:04 PM |
Iv got it on mine and have used it for loads of cars in the past. Never had a problem.
Dan
