Hornet
posted on 10/1/04 at 03:58 PM |
Fiesta Thermostat Housing
Guys
From which model of Fiesta do I get a Thermostat housing for my x-flow?
I did get one this morning, but it has an additional outlet on it for an overflow pipe.
I guess I could still use it after I blank that though?
kingr
| posted on 10/1/04 at 05:13 PM |
Mk1 Fiestas have the correct housing. If you can block the overflow pipe effectively, I shouldn't think it would cause problems.
Kingr
| posted on 10/1/04 at 05:45 PM |
whilst this thread is about i may as well ask a question myself!
what is the reason for the fiesta unit being used? is it because the radiator is below it and it needs venting to remove airblocks, or is the system
filled thru the hole?
my sierra one has a pipe out the top, is this suitable for the kitcar?
my expansion tank will be higher than the thermo, but i guess that essential anyway. is it?!
thanks anyone!
flyingkiwi
| posted on 11/1/04 at 01:20 AM |
As far as the x flow goes the fiesta housing is used to automatically control the radiator fan, switching it on or off as the escort had a direct
drive cooling fan. As for a sierra engine I don't know, and cannot remember if they have a direct drive fan or not. Mind you with the amount of
people making sierra based car's the answer should pop up.
Hope this clear's up the fog a little
Chris
It Runs!!!!! Bring on the SVA!
| posted on 11/1/04 at 02:05 AM |
should've said, mines a 1600 pinto and it was previously a direct drive fan. The new radiator off a polo includes a thermo switch for the
fan.
that help anyone with an answer?!
