mcerd1
posted on 18/10/08 at 04:45 PM |
fitting piston circlips
I've got a set of these: http://www.accralite.com/accralite/Search/PistonDetail.asp?part=1027xc93
anyone got any advice on fitting the wire circlip things (round x-section) - they really don't want to go in
-Robert
Canada EH!
| posted on 18/10/08 at 05:04 PM |
The picture dosn't show the circlip. Have they a hole in each end, if so circlip pliers. If not push one end in gently wth some engine oil on
the piston, then with a blunt instrument (small piece of hardwood dowel) work the other end in place. The clips are there to prevent the pin carving a
slot up the side of the bore. Some racing pistons us a teflon button to cover the pin hole and keep the pin in place.
mcerd1
| posted on 18/10/08 at 05:12 PM |
they don't have loops/ holes at each end - they are more of a snap ring kind of thing...
austin man
| posted on 18/10/08 at 10:45 PM |
Are we talking circlips or piston rings?? circlips will definitelt have a hole in either end, piston rings wont. Piston rings will require a bit of
twisting and stretching to run them down the piston obviously yopu neet to locate the lowest on first you may also fin 2 different kind of rings it is
essential these are located in the correct slos ant that all rings when fitted are aligned with the gaps opossing each other thus preventing oil being
pushed straight up the piston
Chippy
| posted on 18/10/08 at 10:54 PM |
Correction there Austin man, some circlips do NOT have holes each end, they are just a round spring clip that is a bit of a bar-steward to get in. As
said previously just get one end into the gudgen pin hole, and then work the remainder in a bit at a time, once you have done one they get easier,
(liar). Cheers Ray
mcerd1
| posted on 19/10/08 at 03:24 PM |
what Chippy said ^^^
we are talking circlips, but not your normal ones (definatly not piston rings - they were really easy)
these are the kind that hold the gudgen pin in the right place (as unlike the std pinto they arn't a press fit
They are in now but "a bit of a bar-steward to get in" is an understatement
they did get easier, but my fingers also got alot more painfuly
all I can add to the above is you need a tiny (yet strong) screwdriver to help lever them in, using the small slot in the piston (its there for the
job, but still doesn't make it easy)
