Hugh_
| posted on 20/10/08 at 12:47 PM |
Pinto oil pump
I have removed the dizzy from my Pinto and covered the mount with a plate as I'm running a megajolt now. Will the oil pump still work without
the dizzy being present?
| posted on 20/10/08 at 01:01 PM |
You'll need to retain a dizzy body in there to secure the oil pump drive shaft in place and provide and upper "bearing" for it. I
think most people remove the actual workings of the dizzy and then refit it.
flak monkey
| posted on 20/10/08 at 01:07 PM |
No.
You either need to chop up the dizzy, or just leave it in there. Its hardly in the way!
Sera
http://www.motosera.com
Hugh_
| posted on 20/10/08 at 01:14 PM |
Glad I asked, thanks!
DarrenW
| posted on 20/10/08 at 02:56 PM |
I modded my dizzy after fitting megajolt. Just hacked off the main body where the rotor arm sits and filed it round. Cut the shafty a bit so it just
stuch through upper bearing. Worked well and original clamp can be used to hold it in place.
