vinny1275
| posted on 19/2/09 at 08:56 PM |
Clutch cable return spring
Evenin......
Just fitted up the clutch cable, and there's a bit of slack on the clutch fork, which allows the pedal to droop backwards. Where would be best
to put a return spring, on the fork, or the pedal? For ease of fitting, the pedal would be better, any good reason not to?
Vince
flak monkey
| posted on 19/2/09 at 09:00 PM |
You should be able to adjust it out...
Sera
http://www.motosera.com
vinny1275
| posted on 19/2/09 at 09:17 PM |
The adjusters are all the way out.............
Pdlewis
| posted on 19/2/09 at 11:40 PM |
Im looking at putting a spring on mine as the light bec clutch with the quite stiff mnr pedal box needs a bit of somthing to help it
Build Photo Album
Updated 05/02/2009
