Author: Subject: RV8 - unleaded ?
Scotty
posted on 14/3/09 at 08:27 AM Reply With Quote
RV8 - unleaded ?
hi
can anyone give me a clue/quick test to see if my engine is ok for unleaded petrol ?
i'm sure i looked into it when i got the engine but someone has put doubt in my mind
standard rv8 from an sd1, 9.51 compression, unknown age
cheers in advance
PLEASE NOTE! All comments made by this person are to be considered "Tongue in Cheek" and are not meant to be taken seriously in any way - so there!
wilkingj
posted on 14/3/09 at 08:54 AM Reply With Quote
All RV8's are unleaded, unless its a very early P5 or possible some early P6 engines.
(numbers only in the engine number)
If its a SDI then its definately unleaded.
At a worst case, you will need a pair of later heads.
I would run it anyway, as you will get a lot of use before you trash the heads running leaded head on unleaded petrol.
My may got 5 years of 40 miles a day (to work) out of a leaded head on his Landy before it needed doing.
Check your engine number against this site.
If its a 10A onwards, then its definately unleaded.
Linky
I think you really dont have anything to worry about.
Best Regards
Geoff
http://www.v8viento.co.uk
Scotty
posted on 14/3/09 at 02:52 PM Reply With Quote
hi
thanks for that
i'm sure it was but when someone puts doubt in your mind ........
just been for a blat, seems to be going well
