Northy
posted on 17/4/04 at 11:38 AM |
Fitting transducers to a VX block
Help!!!!! Please
I want to order some guages for my car soon and I can not work out how to fit oil pressure and oil temperature transducers to my VX 8 valve engine
Has anyone any knowledge of this?
Ned?
Cheers (hopefully)
Graham
Ben_Copeland
posted on 17/4/04 at 05:23 PM |
Oil Pressure fits in where the oil light sender is... should be a twin poll one.
Oil Temp would have to be drilled and tapped into the sump/block/oil way
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
posted on 17/4/04 at 06:58 PM |
Why can't you take the temp from the same place, it's the same oil isn't it?
Ben_Copeland
posted on 17/4/04 at 07:57 PM |
The VX oil pressure/light sender is huge... dont know if theres an equivilent on the market that'll do all 3 ?!?!
Ben
Roadster
Northy
posted on 17/4/04 at 08:41 PM |
Hi guys,
As I'm not using the standard dials I don't think I'll be able to use a standard VX sender (unless I'm very lucky)
I've been looking into the problem today. There is a plug in the block a little further back and higher than the oil pump that goes into one of
the main oil galleries which is perfect for oil temperature. (Apparently you should fit an oil temp sender where oil is passing over the sender.) This
is M14 x 1.5.
It is possible to replace the standard oil pressure switch (also M14 x 1.5) with a T piece to fit oil pressure switch and oil pressure sender.
So I'm gonna have to get some adapters, M14 x 1.5 to sender thread, and a T piece. Any recommendations?
[Edited on 17/4/04 by Northy]
Graham
Ben_Copeland
posted on 18/4/04 at 05:57 AM |
Can you not get an aftermarket sender that does pressure guage and the light ? Worth looking into.
Its worth looking at getting the plug out and seeing if you can fit anything in there
Ben
Roadster
NS Dev
posted on 18/4/04 at 09:17 AM |
Yes, you can get oil press light and guage type senders, with adjustable "lightup" point for the light too (the standard car ones come on
too late/at too low a pressure, if you are on the track your engine will be in bits by the time the light comes on!)
You can get these from either Demon Tweeks, or better cos you can ask about the pressures etc. from QED tel 01509 412317
ned
posted on 19/4/04 at 08:51 AM |
I'm going to use a capillary for oil pressure from a t-piece in the oil line somewhere as previously suggested. I'm not to bothered about
oil temp if i have water temp, which i'll run off the standard thermostat housing.
Ned.
beware, I've got yellow skin
