Author: Subject: removing a/c and PAS pumps...
franky
posted on 3/2/10 at 06:09 PM Reply With Quote
I'm thinking I can just remove pas+aircon pumps then use shorter pulley belts, is this correct or am I just being dumb?
Miks15
posted on 3/2/10 at 06:12 PM Reply With Quote
sounds fine to me
speedyxjs
posted on 3/2/10 at 06:25 PM Reply With Quote
That will be fine
It depends on what does the tensioning, and whether removing these parts will route the belt through some obstruction and also whether it leaves you with enough "wrap" around the remaining pulleys.
blakep82
posted on 3/2/10 at 06:28 PM Reply With Quote
also just make sure that the things you keep belt driven, don't rely on turning, say anticlockwise, and when you've done your conversion they end up going clockwise (like how some zetec water pumps go the opposite way round to everything else)
i didn't expalin that very well, but i'm sure you get it
________________________
posted on 3/2/10 at 06:43 PM Reply With Quote
I did it on the RS4 engine... I removed the gears as well just in case.
It's Evolution Baby!
franky
posted on 3/2/10 at 06:49 PM Reply With Quote
Yep makes sense.... Make sure things turn the correct way would be the lay mans terms!
daniel mason
PAS and A/C pumps should be worth a bit to the right person too! another good reason for the donor!
Mark G
posted on 3/2/10 at 06:53 PM Reply With Quote
If the engine is still in a car be sure to have the A/C Gas recovered first as it is illegal to vent the gas to atmosphere.
