Author: Subject: X Flow data
Fifer
posted on 4/5/04 at 04:05 PM Reply With Quote
X Flow data
Ordered a X Flow tuning book but till it arrives, anyone out there who can tell me the torque settings for cyl head and rocker post bolts. Also the valve clearances would be nice too and whether they are set hot or cold.
Thanks in advance
pointy
posted on 4/5/04 at 04:45 PM Reply With Quote
I have ford kent crossflow book and it says............are u ready..
cylinder head in 5 stages
1)7nm
2)28-42nm
3)70-76nm
4)90-97nm after 10 to 20 minutes
5) After engine has warmed up (15 minutes at 1000rpm) tighten up to 90 -97nm.
I can give you valve clearance details if you tell me size of engine.
Andy p (pointy)
Fifer
posted on 4/5/04 at 05:18 PM Reply With Quote
Cheers for that.
Sorry, forgot size, it is a 1600
posted on 4/5/04 at 07:00 PM Reply With Quote
What cam are you using?
Check with the cam data for valve settings or you might be defeating the object of fitting it.
Fifer
posted on 5/5/04 at 07:45 AM Reply With Quote
Its an A2 cam Pete
