the man with a plan
posted on 31/5/04 at 03:04 PM |
DOHC Pinto question
Hello,
I'm not really sure if this should go in the "Chassis Section" or here, but anyway...
I am interested in getting my hands on a DOHC Pinto engine, but i understand that there could be a problem getting it into a book chassis, is this the
case?
If so, by how much do I need to increase the height of the engine bay?
Thanks, in advance, for your help.
zetec
posted on 31/5/04 at 03:43 PM |
When you say DOHC Pinto do you mean a Cossie engine or the unit fitted to later standard Sierras which is not a Pinto? If it is the later I would do a
check on past listings for views on the engine compared to SOHC Pinto.
the man with a plan
posted on 31/5/04 at 04:01 PM |
It's coming off a Sierra 2000E (H-reg, i think).
So i guess it is the latter of the two options you suggested
stephen_gusterson
posted on 31/5/04 at 06:29 PM |
thats the 8v dohc non pinto methinks.
take a trip to your local scrappy with a tape measure
atb
steve
Mark Allanson
posted on 31/5/04 at 07:59 PM |
The thing only just fits in a Sierra! The remote water pump one side and the alternator the other, its about 3' wide
AvonBelgium
posted on 31/5/04 at 09:48 PM |
Total height for a DOHC is about 60 cm.
Mark Allanson
posted on 31/5/04 at 09:54 PM |
Total width for a DOHC is about 100yds
stephen_gusterson
posted on 31/5/04 at 10:58 PM |
surely you mean 9144 cm?
atb
steve
Mark Allanson
posted on 31/5/04 at 11:09 PM |
No, it would be 91440mm, I'm not a carpenter!
mackie
posted on 31/5/04 at 11:27 PM |
Can't be as wide as a vee engine surely? I think the RV8 is around 50cm wide excluding exhausts and alternator (which gets moved anyhoo).
stephen_gusterson
posted on 1/6/04 at 09:45 AM |
depends on the Vee - my cologne isnt all that wide low down - its only at the top, where the heas stick out thats there is any width, and thats where
the bonnet is widest. Admittedly, I have to move the power steering and alternator to engine top.....
atb
steve
