Author: Subject: Westy Ratio Help - Suggestions Please
DixieTheKid
posted on 20/9/11 at 08:07 PM Reply With Quote
Evening all,
I'm pretty pants went it comes to ratios etc so im open to all options/opinions regarding my build.
I have a YB Cosworth Lump which will be coupled to a T5 gearbox. I have a 3.14 diff which im going to sell and purchase a LSD. What would be the best ratio diff to try and get bearing in mind i want to put some big alloys on it which leads me onto another question, whats sensible size wheels can be used to fill the arches?
I suppose i should add that the Westy is going to be a bit of a road toy, is not going to see the track that often so it need to be drivable if that makes sense?
Cheers Chris
[Edited on 20/9/11 by DixieTheKid]
COS IT'S Worth IT
Andy B
posted on 20/9/11 at 08:31 PM Reply With Quote
I am afraid I can't help with the ratio side of things but I do have a customer who would be interested in the 314 diff if that helps
Regards
DixieTheKid
posted on 20/9/11 at 08:47 PM Reply With Quote
Regards
Thats diff is drumming up a lot of interest. U2u offer if you like.
COS IT'S Worth IT
Gary 7
posted on 20/9/11 at 09:13 PM Reply With Quote
For the diff ratio if using ford lsd its 3.62 and 3.92 i think. Try this gearcalc , input wheel tyre sizes diff ratios choose gearbox t5 from the list
http://locost7.info/gearcalc.php
Chippy
posted on 20/9/11 at 09:50 PM Reply With Quote
Using the Cossy I would stick with the 3.14 and get an LSD fitted to it. I have the V6 Cossy and am fitting a 3.14 with after market LSD, because the 3.62 LSD just is not long enough. HTH Ray
westy turbo
posted on 21/9/11 at 04:40 AM Reply With Quote
The 3.92 with a T5,works awesome,the only think is it redlines at about 225-230 but how often u going to need more
snapper
posted on 21/9/11 at 06:25 AM Reply With Quote
Let me assure you, you don't need a 3.14 with that gearbox.
The 3.9 is an option but with the Cossy torque a 3.6 will be good for 1st 2nd and 3rd by then you'll be going quick, 4th will take you to any speed quickly and 5 will be a long cruise gear.
I eat to survive
I drink to forget
mcerd1
posted on 21/9/11 at 10:48 AM Reply With Quote
all the rwd sierra cossie's uesd a T5 with a 3.64 LSD (7.5" ) as standard
so you shouldn't be far off the mark with a 3.62 diff for road use - it'll depend a little on your tyre size but you can always go up or down a size/profile for the fine tunning
the standard cossie's use 205/50 R15 tyres - so that'll give you a benchmark
e.g. a 245/45 R16 would be effectivly 7% higher geared than the origonal cossie, but a 185/60 R13 would be ~6% lower geared and so on...
[Edited on 21/9/2011 by mcerd1]
DixieTheKid
posted on 21/9/11 at 06:36 PM Reply With Quote
Whats the norm with regards to wheel size for a 7 or isn't there?
COS IT'S Worth IT
mcerd1
posted on 22/9/11 at 07:13 AM Reply With Quote
not really a normal for a seven as such - most are between 13" and 15" wheels but with all kinds of widths and tyre sizes
I think most of the westfield's use similar sizes but I've no idea what they are
(might be worth asking some of the guys on the westie forum, I know a few of them have YB engines as well)
the ones I do know are the dax's, but they are generaly much bigger. the wide rear arch option is just big enough for 9.5" - 10" wide rims - some folk run as big as 255/40 R17's (mine are 'only' 245/45 R15)
westy turbo
posted on 22/9/11 at 03:14 PM Reply With Quote
8x13 to the front,10x13 rear for my westy ,or go to 15"
DixieTheKid
posted on 22/9/11 at 04:15 PM Reply With Quote
Thanks for that info. Had a lot of interest in the diff, please note its sold. Cheers chris
[Edited on 22/9/11 by DixieTheKid]
COS IT'S Worth IT
