rash12
posted on 11/10/11 at 11:24 AM |
bike carb manifold
im in the process of manufacturing a manifold for a set of bike carbs for my pinto and was after some advice,
what size vacuum pipe should i use for the four take offs from each leg of the manifold, and what sort of size vacuum chamber will i need before the
single vacuum pipe to the dizzy ??
thanks in advance
deezee
posted on 11/10/11 at 11:49 AM |
About 3mm ID will be fine for your vacuum take off. A reasonable sized vacuum reservoir / chamber would be around 2" diameter and 4 inches
long.
RAYLEE29
posted on 11/10/11 at 12:03 PM |
hi, is it really necessary to have a chamber and that seems excessive to me just for the vac advance on the distributor.
Ray
build diary1
http://picasaweb.google.com/raylee290/RoadsterPics#
build diary2
http://picasaweb.google.com/raylee290/KITCARPICS?authkey=Gv1sRgCI2AouyYgpuQmAE#
blakep82
posted on 11/10/11 at 12:15 PM |
Ray
yeah, it helps to smooth out the vacuum from each runner on the manifold. if you just took 1, it would pulsate, so you need all 4 really, they still
pulse though, so it helps smooth the pulses out to give a nice steady vacuum
________________________
RAYLEE29
posted on 11/10/11 at 12:34 PM |
ta, but does the plenum really need to be that big? 2"od x 4" long? for mine i was planning on running the four pipes tee'd together
then to the vac diaphragm.
maybe a plenum made from a 1/2" tube slung under the runners would be better and neater?
Ray
build diary1
build diary2
snapper
posted on 11/10/11 at 03:34 PM |
I've got a plenum made from 10pm pipe 100mm long, seems to work on my Megajolt ok
I eat to survive
I drink to forget
jacko
posted on 11/10/11 at 04:36 PM |
A mate of mine made one out of 22mm copper pipe about 70mm long and caped the ends with pipe ends, then soldered 4 tubes in one end and one pipe in
the other ,
This worked very well
Jacko
rash12
posted on 12/10/11 at 06:54 AM |
manifold
thanks jacko i had a similar idea in mind i was going to do the same with a shorter piece of 42 mm copper tube
