Author: Subject: Raw striker diff
mkeats02
posted on 13/1/12 at 11:50 PM Reply With Quote
Raw striker diff
Does anyone know whether it matters if a 7" or 7.5" diff is used on a striker?
Going to try and pick up a 3.91 or 3.92 diff to use.
Thoughts on LSD v NON-LSD?
Mike
Dopdog
posted on 14/1/12 at 08:12 AM Reply With Quote
Hi
my old striker was a 7in diff so would check before as i do not think the 7.5 was fitted to them, also i would go for the lsd if the track is where your going, if not i would not bother.
loggyboy
posted on 14/1/12 at 08:48 AM Reply With Quote
Yeah, unless spec'd otherwise from the factory, it will be a 7".
bi22le
posted on 14/1/12 at 09:55 AM Reply With Quote
There are quite a few different set up with the strikers depending n use. The old ones used trailing arm real sus which is still a god set up.
I have what is pretty much a T150. I have a 7" non LED with rear IRS and was told by quite a few people that this is the best set up for less than 200bhp.
so if tour aiming above 200 when i would suggest LSD.otherwise don't bother.
I don't know of any running a 7.5"diff.
HTH
Please read my ring story:
posted on 14/1/12 at 03:45 PM Reply With Quote
The IRS striker uses the 7" diff. The 7.5" is wider across the mounting points so will not fit without chassis modifications. It's also quite a bit heavier and really not necessary for such a light car.
mkeats02
posted on 14/1/12 at 06:55 PM Reply With Quote
Cheers guys.
Would you trust a diff from eBay?
Mike
loggyboy
posted on 14/1/12 at 07:33 PM Reply With Quote
Are you going down a donor or new components or Q plate route?
mkeats02
posted on 14/1/12 at 07:57 PM Reply With Quote
Planning on going new reg route.
I understand that there is not too much focus on the components providing they look new.
New diffs are pretty expensive.
I am going new zetec, bgh gearbox, new steering components, braking and chassis etc.
loggyboy
posted on 14/1/12 at 08:03 PM Reply With Quote
Sounds identical to my plan!
I have one diff I bought off ebay for about £20, seemed ok, but mainly bought it for trying out how it would fit etc. I have no idea if it works under load. I have picked up a full sierra too, not really for donor parts as such, more for an exhange gearbox, (or places like BGH etc add surcharges) I also know it all works.
mkeats02
posted on 14/1/12 at 09:40 PM Reply With Quote
Seen this one
FORD SIERRA # REAR 392 DIFF UNIT 7' # KIT CAR RACE RALLY COSWORTH HOT ROD LOCOST | eBay
Thoughts?
Recon diffs can be picked up for £400 or one from raw £200
loggyboy
posted on 14/1/12 at 10:38 PM Reply With Quote
Pretty sure the 3.92 diff isnt the rarer ones, and ok if you want a tourer/crusier but may lead to quite long ratios.
3.14 are the sort after ones IIRC, better acceleration but lower top end.
I think the 2 I have a re 3.6 and 3.9, so I may use mine to play around with what feels best on the road.
If your in no rush then shop around, but if you get a knowledgeable DVLA person (unlikey i know) you will want a (convincing) reciept for the 'new' Diff!
[Edited on 14/1/12 by loggyboy]
mkeats02
posted on 14/1/12 at 11:48 PM Reply With Quote
It is my understanding that a lower ratio ie 3.14 gives better top end and MPG opposed to higher ratio ie 3.91 gives better acceleration.
loggyboy
posted on 15/1/12 at 09:20 AM Reply With Quote
Oh, maybe the 3.14 is popular for the bike engines to control their acceleration and lower revs for cruising then...!
ian locostzx9rc2
posted on 15/1/12 at 10:29 AM Reply With Quote
3.9 better acceleration lower top speed
