cliftyhanger
posted on 3/6/12 at 10:26 AM |
Zetec/cvh sump baffling
having searched here and elsewhere I am now scratching my head wondering what to do.
I have the CVH sump, tweeked to it fits the zetec with the correct pickup. Now, what should I do to baffle it. The car will see trackday use, but
probably not reach the lateral g-forces encountered with most kits (it is going in a Triumph Spitfire) however, I want to avoid any potential issues.
So, any nice, simple instructions ideally with pics? Pleeeese
Ta
Clive
cliftyhanger
posted on 3/6/12 at 10:32 AM |
NB
Just seen this Ford Sierra 1.8 CVH Sump & pick up Pipe for Zetec Conversion For RWD , NO RUST | eBay
and my sump has not got the fitted plate. I presume it is a factory item?
Would making one similar, maybe with a couple of vertical plates, be suitable?
big_wasa
posted on 3/6/12 at 10:46 AM |
All the 1.8 cvh sumps Ive played with have that baffle. Its spot welded in place and not easy to remove.
Christ is that what they are fetching these days ?
cliftyhanger
posted on 3/6/12 at 11:17 AM |
Don't fret, mine was rather cheaper!
I am a bit miffed that it is missing. Still, should be easy to re-create. Was thinking of adding plates that almost reach the bottom of the sump
(corners cut off etc) to create a "box" around the pickup. Not too close though, and try to shape the large plate to direct oil into the
"box"
mark chandler
posted on 3/6/12 at 02:41 PM |
Horizontal baffles stop surge, vertical ones only work with trap doors!
