beqa16v
posted on 10/6/12 at 01:40 PM |
Bike carbs needle movement
Hello guys
Sorry for opening a new thread but I'm really in a hurry with this
I have carbs from ZZR750 which are so called E carbs where you have to put small washers to adjust needle position. Needles on my carbs were moving
freely inside the slider up and down at some extent. I put two 0.5 millimeter washers under them.
Now that I have assembled them, they have movement inside the slider as well but it is spring resisted movement, not a free movement in all carbs but
one.
How should it be? Should the needles move freely in sliders, should they be stuck or should they move with spring resistance?
snapper
posted on 10/6/12 at 02:14 PM |
The slider is pulled up by diaphragm above the spring helps to damp the movement, the needle is held in the slider by the spring.
In operation this should be ok
I eat to survive
I drink to forget
beqa16v
posted on 10/6/12 at 02:20 PM |
What is correct?
Free movement of the needle inside the slider (not with slider) or movement inside the slider with spring resistance?
Three needles move with spring resistance, one moves freely without any resistance.
