Dick Axtell
posted on 21/6/13 at 09:05 PM |
Polo Rad Fan Switch - Connection & Waterproofing
Hello LCBers.
Those of you who have used the Polo rad will have come across this prob. Which connector did you use, for the Polo switch?
And more importantly, how did you seal it against water ingress?
I'll read your comments with interest.
posted on 21/6/13 at 09:25 PM |
Easier just to buy a Renault or Fiat fan switch it has standard 15 amp Lucar blades
RENAULT EXTRA VAN FAN SWITCH 86 87 | eBay
matt_gsxr
posted on 22/6/13 at 05:57 AM |
I used a Passat switch that had spade connectors.
Never worried about water ingress and 5 years in I have had no trouble.
Can't remember the part number but it didn't seem like a rare thing.
Matt
renetom
posted on 22/6/13 at 06:49 AM |
Hi
Just used regular insulated crimp connectors
on both the switch & the fan never had any problems with water ingress
If you are that worried use the crimp connectors & encapsulate them with silicone.
Good luck.
[Edited on 22/6/13 by renetom]
cliftyhanger
posted on 22/6/13 at 07:15 AM |
Again, spade connectors here.
If concerned, give the connections a squirt of protection wax or even chain lube.
(I find the aerosols of protection wax handy for all sorts of stuff!)
loggyboy
I made my own water proof connector, not sure if its similar to the connector on the rad switch but worked well for the speedo sensor on my c20xe.
I didnt have the correct crimper, so I just pinched them with pliers best I could
Hot glue gun to seal it all up.
Mistral Motorsport
big_wasa
posted on 22/6/13 at 07:54 AM |
I swap the switch or find a connector from a scrap yard.
Not the flat three pin one is it
Dick Axtell
posted on 22/6/13 at 07:56 AM |
Thanks evryone for the feedback. Some very useful, and interesting, info in your replies.
Dick Axtell
posted on 22/6/13 at 08:00 AM |
Mine is very similar to this one. Lucar type blade contacts, and there are 2.
big_wasa
posted on 22/6/13 at 08:26 AM |
Just fished this out of the bin. Its from a caddy/Polo with a two stage switch. The same plug is also used on the single stage switch with one wire
left out. Then they went to a round type.
