Author: Subject: manifold wall thickness
andrew-theasby
posted on 7/11/04 at 02:07 PM Reply With Quote
I have a big box full of mandrel bent stainless tubing in different sizes and angles which i was going to build my manifold with but after a bit of searching it seems most people are using 18swg and the stuff i have is mainly 22swg. Will this cause a problem or is it just cause its easier to weld and bend the thicker tubing? I suspect it may crack with time, but is it worth the effort seen as how its free
NS Dev
posted on 7/11/04 at 09:43 PM Reply With Quote
as far as I know it's just the ease of welding that's the issue. As long as you reinforce the pipes where they join the thick manifold plate to stop cracking there you should be ok. Have a look at the way Vauxhall did it with the std manifold, the bent plates under each runner stop the tubes cracking off.
Simon
posted on 7/11/04 at 11:42 PM Reply With Quote
Andrew,
I used 16swg (approx 1.6mm) but that was mild steel.
You may get away with it. As you've already got the box of bends, you might as well try it!
Simon
rocket
posted on 12/1/05 at 10:05 PM Reply With Quote
never use less than 18g. 16 is best for st/st mild should be 16g/14g as it has a lower melting point. anything less than 18g will have a tendency to crack within the first few runs.
Rgds
Roger www.shinybitz.co.uk
