joneh
posted on 12/6/15 at 02:10 PM |
Type 2 release bearing
To remove the clutch release bearing from a Type 2 gearbox do I just pull it as hard as I can? Or does it twist etc?
Jon
benchmark51
posted on 12/6/15 at 03:03 PM |
If you pull the clutch fork outward releasing it from it's pivot, pull the bearing off the shaft. I tink
joneh
posted on 12/6/15 at 06:10 PM |
Arghhh! It doesn't seem to want to budge. I've pulled the bearing out and now the fork is held in by a plastic inner bearing part with
wings. It doesn't seem to turn and I can't pull the fork away from the pivot pin.
Help!
benchmark51
posted on 12/6/15 at 06:38 PM |
If the fork is released from the pivot,as you pull the bearing(and carrier) the fork will come out with the bearing
joneh
posted on 12/6/15 at 06:57 PM |
It's not released from the pivot, doesn't seem to move left or right and pulling out the other side hits the bell housing
Paul Turner
posted on 12/6/15 at 07:17 PM |
A screwdriver between the plastic bit of the carrier and the clutch arm will pop the carrier/bearing off.
joneh
posted on 13/6/15 at 09:42 AM |
That did it! Easy when you know how. Thanks for the replies chaps.
