Millworm
posted on 3/12/15 at 06:21 PM |
Zetec not starting
I recently done a conversion on my sierra, used to be a 2.0 pinto and the engine is in wired up and just cranks, fuel pump primes properly, just
wondering if anyone has any information for testing where I should have power ect as somthing isn't right obviously. It's a silvertop on
an early mk1 mondeo loom with a dewy ecu. I have a 12v at the centre of the coil aswell but haven't checked for spark yet. Just gathering
information for the weekend so I can get at it in daylight. Cheers guys
big_wasa
posted on 3/12/15 at 07:19 PM |
Any chance the engine was from an automatic. That's the favourite gotya with a zetec.
Millworm
posted on 3/12/15 at 08:59 PM |
Nope manual, removed it myself
big_wasa
posted on 3/12/15 at 09:16 PM |
What flywheel did you use ?
Millworm
posted on 3/12/15 at 09:18 PM |
Mondeo 2.0 one, 2.0 clutch and mk1 tranny relaese bearing. Tried for ages to get a fez si loom to make it simpler but no luck. My mondeo one is crusty
in places injector loom is quite bad
Millworm
posted on 4/12/15 at 06:10 PM |
I've managed to get an escort cab loom to replace my mondeo one as it turned out a lot of the wires covering had come away so there where a lot
of short curcits, was ok until I disturbed it by removing g it out the mondeo. I assume this loom being from a j reg will be even more basic than
mine. Does anyone know anything about these looms
big_wasa
posted on 4/12/15 at 07:19 PM |
Pre Pats is pre pats. Same just numbed different.
Millworm
posted on 4/12/15 at 08:47 PM |
Ok then, I'll still take a look at the car this weekend in the daylight. And see if I can find what's causing it. What's the minimum
it'd run with attached?
posted on 4/12/15 at 09:48 PM |
Use a 2 to 5 watt test lamp as a Noid lamp to check if the injector (a) have a constant 5v when ignition is on and (b) are getting a pulse switching
them to ground the circuit when cranked. It should to be a conventional incandescent bulb lamp to put enough load on the circuit to test it.
You can use the same lamp to check the ignition for HT spark connect one wire of the lamp to ground and hold the other end close to the end of the
plug lead.
CAR 6V-12V TESTER LIGHT LAMP VEHICLE DC ELECTRICAL CIRCUIT TEST PROBE 6-12 VOLT
Good scanndanner Youtube info video link ScannerDanner link
Millworm
posted on 4/12/15 at 11:46 PM |
Cheers will try that tomorrow
Millworm
posted on 5/12/15 at 05:19 PM |
All up and running, was missing an ecu earth! And had a small issue with fuel lines like connected the wrong way (facepalm) Cheers for your help guys
couldn't have done this conversion without you all
