smart51
posted on 17/1/05 at 10:02 PM |
2.0i duratec engine
Does the duratec engine bolt directly to a RWD gearbox like a zetec?
zetec
posted on 17/1/05 at 10:07 PM |
No. You will need a adaptor plate or bellhousing.
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
CairB
posted on 17/1/05 at 10:30 PM |
It will bolt to a type 9 with a bellhousing from Shawspeed, BPJ, Raceline, Titan etc. It has also been fitted to an MT75 with an adaptor plate.
Are you thinking of using one?
Be wary when buying a Duratec though there I have heard of many tales where are 1.8's being passed of as 2.0's (allegedly).
Colin
stevebubs
posted on 17/1/05 at 10:54 PM |
? So Ford have broken a 30 year old tradition and changed the block bellhousing bolt pattern? The only question I have to ask is "Why?"
posted on 17/1/05 at 11:11 PM |
dont zetecs need adapters as well?
locost_bryan
posted on 17/1/05 at 11:58 PM |
IIRC it is based on the Mazda MZR (Mazda3/6) used in the Mazda B2300/Ford Ranger light trucks (USA), mated to a Mazda gearbox. Not sure if it's
the M-series box (MX5, na RX7) or R-series (RX7TT, RX8) - former has integral bellhousing, latter has separate bellhousing & bigger &
stronger.
How does the engine compare size-wise to a Pinto?
Bryan Miller
Auckland NZ
Bruce McLaren - "Where's my F1 car?"
John Cooper - "In that rack of tubes, son"
stevebubs
posted on 18/1/05 at 01:04 AM |
Nope.
I've mounted my blacktop zetec straight onto my Type 9
Even managed to use a 1.8 CVH dust plate, although I had to take the grinder to it in order to reshape for the oil pump diameter.
stevebubs
posted on 18/1/05 at 01:05 AM |
stronger.
Mazda's been pretty much owned by Ford for the last 15 years or so. So I still have to question WHY they've made the change...after all,
the Zetec-S was a Yamaha design.
stevebubs
posted on 18/1/05 at 01:14 AM |
stronger.
BTW I'm not questioning the fact that it *is* different, just the logic that made Ford forsake their "standard" bolt pattern
mangogrooveworkshop
posted on 18/1/05 at 11:16 AM |
quote: Originally posted by Syd Bridge
In Aus, small Fords have been rebadged Mazdas for some time, Maybe signs of things to come?
Thats been standard practice for the Blue oval in South Africa for the last twenty years +- under the name samcor . This was to make low volume
markets more profitable.
quote The result was a reduction in the cost of vehicles as manufacturers turned to low-cost imported parts in order to increase the percentage of
value represented by local products. The lowered cost of assembly was evidenced in June 1991 when the South African Motor Corporation (Samcor)
announced that it had started exporting locally assembled Mazdas to Britain.
mmmm zoom zoom zoom!
[Edited on 18-1-05 by mangogrooveworkshop]
CairB
posted on 18/1/05 at 07:13 PM |
Have a look at: Duratec v Pinto
flak monkey
posted on 18/1/05 at 07:19 PM |
A few year back the fiesta and mazda 121 were the same car here in the UK. Saw a few around.
Sera
http://www.motosera.com
DarrenW
posted on 19/1/05 at 09:18 AM |
Another thing to watch out for with Duratecs. I have heard that the Focus ST170 is badged as duratec but is actually closer technically to a zetec.
Can anyone confirm / deny this? I would hate someone to pay a high (ST170 style) premium for a zetec.
