Author: Subject: Anybody use Subaru engines?
kreb
posted on 23/2/05 at 09:09 PM Reply With Quote
I like the idea of the low cg, and the EJ22/EJ25 engines seem reasonably light and powerfull. Any experience out there?
https://www.supercars.net/blog/wp-content/uploads/2016/04/1966_FiatAbarth_1000SP1.jpg
clbarclay
posted on 23/2/05 at 09:13 PM Reply With Quote
Flat 4's, how wide an engine bay is that going to need.
No idea what the front drive is like, but does anybody know how easy it would be to drive wheels in front of the engine rather than wheeels that are along side the engine?
If the 4x4 system is unusable then it take away one of the major pros fro usiong a scooby engine/transmission.
I presume you are planning a 7 style car.
[Edited on 23/2/05 by clbarclay]
posted on 23/2/05 at 10:26 PM Reply With Quote
my ideal use of a subaru engine would be a middy with a turbo engine, bolted to one of the original 2wd impreza gearboxes. Not sure if it could handle it!
a tip from my mate who rallys subarus, is use the block from a legacy and the heads off an impreza. Apparently, the legacy engine has a better water jacket for tuned abuse.
stephen_gusterson
posted on 23/2/05 at 10:31 PM Reply With Quote
you would never get a flat 4 in the front of a seven replica!!!!!!!!
atb
steve
MikeR
posted on 23/2/05 at 10:50 PM Reply With Quote
yes you would..... it would just have to be either a wide seven or turned 90degrees on its side
(that was another post from the useful post society!)
posted on 23/2/05 at 10:52 PM Reply With Quote
if memory serves, the impreza engine is about 4 feet wide - that takes 7 to a whole new un7 level!
kreb
posted on 23/2/05 at 11:37 PM Reply With Quote
yeah, it looks like it might be viable for a middy, but certainly not anything like the book chasis, unless..... What if you ran it like a horizontal twin BMW? Can you imagine heads sticking out of either side of the frame? Lol!
Dale
posted on 24/2/05 at 12:51 PM Reply With Quote
Just stick the heads out through the sides of the chassis like the beamer bikes
Dale
clbarclay
posted on 24/2/05 at 01:33 PM Reply With Quote
Dale
Unless you move the froont wheels forward you will not have enough steering lock before the wheels come into contact with the cylinder heads.
kreb
posted on 24/2/05 at 02:16 PM Reply With Quote
I've talked to a couple of people who have measured it and say that it can be done with a McSorley +4 (my preference anyway). It' s gonna be a squeeze no matter how you slice it, and you'd probably have to mount the engine/tranny seperately, which is a PITA. Are the motor's good qualities worth the trouble? I dunno. Maybie.
ned
posted on 24/2/05 at 02:24 PM Reply With Quote
steering column location might be an issue as well as the engine width..
Ned.
beware, I've got yellow skin
NS Dev
posted on 24/2/05 at 02:37 PM Reply With Quote
what exactly are the engines' "good qualities"??
I know it is fairly light and very low, but it is also fragile (bottom end failures very common) expensive to replace parts on and more difficult to extract power from than it's other turbocharged opposition, like the Mitsubishi engine and the toyota turbo engines, both of which are much tougher.
The breaker that I know had a containerful of knackered Subaru engines, around 15 I think, all bottom end failures after being "chipped"!! I think they went for scrap metal in the end!
kreb
posted on 24/2/05 at 03:38 PM Reply With Quote
My experience with them is different. A friend has a WRX which I fabricated bits and pieces for in exchange for seat time. I didn't fancy the turbo lag, but otherwise thought it a great car. It was one of the first WRXs out in the US, and the only thing that has gone wrong is that his first gear syncros are toast. You have to figure that the engine in a car that is less than half the weight and only distributing power to one set of wheels will be much less stressed than it's original placement.
But I'm no expert. That's why I'm asking.
Mark18
posted on 24/2/05 at 10:08 PM Reply With Quote
I think your Imprezza WRX's use 2.5litre engines as opposed to the 2litre ones over here.
Mark
"I don't know what I may seem to the world. But as to myself I seem to have been only like a boy playing on the seashore and diverting myself now and then finding a smoother pebble or a prettier shell than the ordinary, whilst the great ocean of truth lay all undiscovered before me." - Isaac Newton
kreb
posted on 24/2/05 at 10:51 PM Reply With Quote
nah, we've got the 2.0s too. They are using the turbo 2.5s on other products though.
I'm surprised to hear the Subarus depicted as mechanically defficient. Over here, the WRX's are thought to be very tight - with the exception of the gearbox if you're one to abuse it. The Mitsus on the other hand are somewhat suspect. One thing that Mitsubishi did to alienate their US customers is a web search trying to link Evo owners with race results. If they found any instances of "racing" the Evo owner promptly got a letter that his warranty was void. - Even if the racing was as innocent as gymkhana (We call it autocross)!
MikeR
posted on 25/2/05 at 12:06 AM Reply With Quote
The big plus with this engine is the smoothness, low centre of gravity....... and the perception that its a big powerful thing that must be strong cause its rallyed.
i like the idea of them, just not the service costs. I seem to remember talking to a mechanic friend who did a cam belt change as a favour and "only" charged 600 quid where the dealer wanted the best part of a 1000!!!!!
kiwirex
posted on 25/2/05 at 07:43 AM Reply With Quote
Originally posted by clbarclay
No idea what the front drive is like, but does anybody know how easy it would be to drive wheels in front of the engine rather than wheels that are along side the engine?
Not much hope it's a transaxle at the front.
You can get a plate (apparently) for the new 4wd boxes to convert them to 2wd - I'm sure the latest impreza box would handle it.
- Greg H
NS Dev
posted on 25/2/05 at 08:22 AM Reply With Quote
That's right Mike, the engine is very smooth, and has a very low centre of gravity when installed. me and a mate put one in a 4x4 spaceframe offroader used for rounding up sheep on his farm in Northumberland, and it was very good.
As you also say, the downside is that because they are rallied, people think the engines are strong, which, relatively speaking, they are not. Yes, they will last a good mileage as a std engine but people used to the Cosworth YB turbo engines (sierra cosworth) and the Mitsubishi EVO engines will be sadly surprised by the Subaru. Over 300hp on the std bottom end is a very big no no, whereas my mate's Sierra was making over 300hp @ wheels on std crank and rods etc with no problems at all.
Yes, in a locost the Subaru engine will no doubt be fine, but there are much better options which are as light, cheaper, need no mods to the chassis design to fit etc etc!
posted on 25/2/05 at 08:36 AM Reply With Quote
yup, i thought they were strong but my mechanic friend laughed his arse off as he put me straight - it is just a myth from the rally front.
then again, i bought one with a bottom end knock and never bothered fixing it. nor did the bloke i sold it to. AFAIK. it lasted several years with just a quiet knock.
