Author: Subject: Zetec Hose Sizes
saigonij
posted on 28/3/05 at 09:27 PM Reply With Quote
Zetec Hose Sizes
All,
putting a Zetec in our Luego.
What size hoses do we need?
1) Top hose outlet to rad
2) Water pump to rad?
the heater take offs we are just looping round as we dont have a heater.
Thanks,
stevebubs
posted on 28/3/05 at 10:45 PM Reply With Quote
32mm for both...blacktop engine
Brr...it's a trifle chilly out there when we've had a nice day
[Edited on 29/3/05 by stevebubs]
saigonij
posted on 29/3/05 at 07:05 AM Reply With Quote
is that for both the thermostat outlet and the water pump outlet? The water pump outlet seems a lot bigger in diameter?
zetec
posted on 29/3/05 at 07:14 AM Reply With Quote
Your right, the thermo to rad is 32mm. I used a reducer samco elbow for the pump outlet, I seem to remember it was 38-32mm, but best check first.
stevebubs
posted on 29/3/05 at 07:39 AM Reply With Quote
Put the calipers round both outlets. Thermostat was just under 32mm, and pump exactly 32mm.
Is a blacktop, though - so the pump may be different (am using a silvertop thermostat housing)
zetec
posted on 29/3/05 at 08:08 AM Reply With Quote
Mine is an earlier engine using a 1800 Fiesta water pump, 1994.
Micael
posted on 30/3/05 at 10:14 AM Reply With Quote
As I can recall the pump inlet was 44 mm. Its a Greytop with standard Escort pump
Micael Moose Åman
Petrolhead and all around nice guy
"Don't leave the duck there. It's totally irresponsible. Put it on the swing, it'll have much more fun." //Sleep Talkin Man Dec 23 2009
saigonij
posted on 30/3/05 at 04:07 PM Reply With Quote
cheers.
mine is a greytop.
what did you do about the actual pipes? they are different diameters to the rad inlets, and also a fair distance?
any places we can get the same from?
Micael
posted on 31/3/05 at 10:10 AM Reply With Quote
I used a mix of rubber hoses, copper pipes, copper pipe reducers and some exhaust pipe.
I had no problems finding sutible pipes and hoses.
The tricky part was the pump inlet (44mm). I have LHD and the steering column passes just outside the inlet.
Micael Moose Åman
