Chaz
posted on 16/6/05 at 09:05 AM |
1.8 Zetec
What car would be the best donor for a 1.8 Zetec (obviously just the engine).
1. Mondeo 1.8 (i heard talk about a large sump or is it the same size as the escort?)
2. Escort 1.8
3. Escort 1.8 GTi
4. Escort 1.8 XR3i
Mix
posted on 16/6/05 at 09:28 AM |
Escort because the sump is about an inch shorter and the water pump rotates the correct way.
Did they make a Zetec version of the GTi and XR3?
Mick
Chaz
posted on 16/6/05 at 09:34 AM |
Nice one.
Well, i dunno really i'm just going from this site. www.zetec-cat.co.uk
big_wasa
posted on 16/6/05 at 10:47 AM |
cheapest would be the 130 spec orion..
the 130 spec escorts are very popular and hence hold there price..The differance between these and the lesser spec is the ecu and the cams.These come
in the xr3i and others.You will be paying the extra for the cams as you will be dumping the ecu if you use carbs..
Make sure its a manual or you will not get a fly wheel and the vr sensor housing is wrong aswell.
As said befor avoid the mondeo lump unless you plan on spending money on the bits described.
Danozeman
posted on 16/6/05 at 10:53 AM |
Big wasa says it all.. Unless your lucky like me and get the 130 cams for little money for the mondeo lump. although i still need a chopped/escort
sump.
Dan
B@man
posted on 16/6/05 at 08:13 PM |
Escort lump is easier, the water pump is usually the correct rotation and the sump is much easier to mod.
You can mod the Mondeo Sump but by the time you have finished there isn't much Ford Metal left.
Appart from the water pump and the sump there is little to choose from, however choose carfully there are three types of 1800 Zetec :
105 PS
115 PS
130 PS
As stated above the 130PS lump is sought after so its expensive, I gave up looking for a 130PS and bought a low mileage 115 PS unit, with twin weber
40's and dunnel ignition it churns out around 145bhp
Projects :
Robin Hood S7 - Deceased !
SSC Stylus 16v - Sold
Spartan Zetec conversion
Rickman 2.0 Petrol (New Engine) - Sold
Rickman 1800 TD (ongoing)
TVR 400SE (Nearly a kit ?)
