Author: Subject: Oil change for Sierra Diff
Paul (Notts)
posted on 3/7/05 at 06:33 PM Reply With Quote
Any Tips.?
Whats the best way to drain the Diff ..?
How much Oil will I need..
I think your ment to fill ot to 10mm below the drain plug when its level ???
assumng I can get the drain plug out...
Thanks Paul.
posted on 3/7/05 at 08:06 PM Reply With Quote
10 mm allen key and a piece of pipe , give it a good yank , it should shift. If all else fails mig weld a nut on , heat from welding and being able to apply more torque will shift plug. If diff is not yet fitted to chassis tip diff on end to drain , if already in chassis try to drain using sucktion/syphon but suspect oil may be too thick to syphon.. fill until oil runs out of filler refit plug
Dillinger1977
posted on 3/7/05 at 08:07 PM Reply With Quote
my drain plug was fused and ive no welder to free it, so i filled mine via the breather pipe at the top. very slow, but doable.
-Rog
smart51
posted on 4/7/05 at 07:03 AM Reply With Quote
about a litre should do it, unless you wipe the inside clean as well as draining it, in which case you might need a smidge more.
Mr G
posted on 4/7/05 at 12:38 PM Reply With Quote
If its LSD......
