toothbrush
posted on 4/7/05 at 11:31 AM |
oil breather crank vent position
I've got a 711m x-flow block that I'm trying to fit a crank breather & oil catch tank to. Burton Power sold me a 90 degree elbow to
fit into the block to vent the crank from, telling me "it goes down by the fuel pump". WHERE ? I've looked and I can't find
either a hole or a core plug to remove to fit this part to. If anyone can enlighten me I would be most greatful. (I have looked at the archive but all
the posts seem to cover plumbing the catch tank in, not where on the block the vented vapour is coming from).
Thanks,
Ian
paulf
posted on 4/7/05 at 11:34 AM |
It fits just above the fuel pump, there is a oil seperator box fitted there as standard, you will need to remove this first and replace it with the
elbow.
paul
posted on 4/7/05 at 11:35 AM |
Face the right-hand intake side of the engine. The fuel pump is roughly in the middle, just above the sump. Just to the left and slightly higher is
the hole for the vent.
Previously this would have a small rectangular box pushed into it, with a rubber pipe from the other end that goes to the inlet manifold.
Does that help?
