DEAN C.
posted on 25/4/02 at 10:13 PM |
SAAB CLUTCH CYLINDER
Hi, does anyone know the part number for the saab concentric clutch slave cylinder,that some builders have used to fit Toyota 4age to a Toyota t50 box
when you have no room for an external cylinder.
I know Eddy McClements has used one on his site .
paulbeyer
posted on 26/4/02 at 09:50 PM |
Hi Dean
I own a Saab and use Euro Car Parts for bits http://www.eurocarparts.co.uk Their website should provide you with the info you need. If not give them a
bell, they should be able to sort you out, and their prices are V. good.
Paul
DEAN C.
posted on 26/4/02 at 10:01 PM |
Thanks ,but after looking at their website I have found various cylinders for the saab's but I'm not sure exactly which car model/year etc.any
ideas?I know most of the late stuff have external cylinders.
Might have to ring them if I cant find out for definate,there is a big variation in price too, for different year/models.
Thanks for the advice.
TL
posted on 6/10/04 at 12:08 PM |
I'm resurrecting on old thread here but can anyone tell me if the concentric slave cylinder used on hydraulic mondeos etc can be used? Everyone
seems to use the saab one, and it seems to me that the ford one should be more compatible and maybe cheaper? My application would be with an MT75 box
Terry
WIMMERA
posted on 6/10/04 at 12:34 PM |
I used SAAB part No 4776308 cylinder with a 8721995 release bearing
Wimmera
TL
posted on 6/10/04 at 04:50 PM |
Thanks Wimmera,
What gearbox were you using?
Terry
DEAN C.
posted on 6/10/04 at 06:43 PM |
Bloody hell,forgot about this post.
The Zetec one is bulkier and looked much more awkward to fit,the Saab unit is much neater,and at the state of Ford prices now I would say the Saab
unit is cheaper at about £35 ish from Europarts,look at their website and you can order one direct.
DEAN C.....
Once I've finished a project why do I start another?
TL
posted on 6/10/04 at 10:09 PM |
I did a search using Wimmera's Saab part numbers, and came up with AP racing website, which has a nice dimensioned pdf of their (saab
interchangeable) unit.....which was nice!
Terry
WIMMERA
posted on 6/10/04 at 11:37 PM |
Terry
I'm using a Toyota T50 box
Wimmera
eddymcclements
posted on 12/10/04 at 10:03 PM |
The Saab clutch slave cylinder I used came from Euro Car Parts and is for (I think) a Saab 99. I believe that some Saab 900 models also used it, but
not the 9000. Whatever, the part numbers you need are:-
cylinder is 4776308
bearing is 8721995
Hope this helps.
[Edited on 12/10/04 by eddymcclements]
NS Dev
posted on 15/10/04 at 06:43 PM |
Above advice is spot-on. I am using one on my Ford Type 9 gearbox fitted to Vauxhall XE 16v engine. Machine up an adaptor to attach the release
cylinder to the 4 bolts that usually retain the trumpet housing on the front of the box. Counterbore the adaptor to take the seal that usually sits in
the rear of the trumpet housing.
Here's a pic of the same done to a Fiat 'box.
[Edited on 15/10/04 by NS Dev]
