MK7
posted on 9/5/03 at 07:25 PM |
How many CC can I squeeze fron a Pinto 1800 rebore?
I've bought a sierra 1.8 LX with a pinto engine as a donor. I bought it cos I read that the 1800 and 2000 engine blocks are the same. Is it true
and if so, is it possible to re-bore the block to 2063cc?
chrisg
posted on 9/5/03 at 08:23 PM |
Don't know about the 1.8 but why not start with a 2.0 that you know will go to 2.1?
They're cheap/free
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the
error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
martin s
posted on 10/5/03 at 02:39 PM |
dont bother
you can pick up a 2litre dirt cheap and get it bored for the same price as an 1800.
chrisg
posted on 10/5/03 at 05:37 PM |
Is there an echo in here?
Chris
jollygreengiant
posted on 12/5/03 at 06:13 PM |
Just to add my 10p worth, all be it late.
1.8 & 2.0 use the same block (technically) and crank, only the pistons and cylinder bores are different.
The block would have a wall thickness appropriate for the cc. rebore would be viable but you would probalbly have to have new liners fitted,
otherwise you would have reliability issues.
start with a 2.0 as your basis, or if cc are that important get alanb to find you an american 2.3pinto and ship it over.
enjoy.
Sorry about the echo chrisg.
Alan B
posted on 12/5/03 at 09:42 PM |
Yep, plenty of them here.....many with turbos.......mmmm
MK7
posted on 15/5/03 at 11:09 AM |
Thanks to all for the input. I think I'll get me a 1993 pinto from the scrappy and work my way up from there.
Dave_the_sparks
posted on 20/5/03 at 04:22 PM |
I have a 2.0 pinto and im having the block planed to up the compression ratio, im told by a tuning friend that this is a more effective way of uping
power output, dont plane it too far!!
there is a book on power tuning pintos, i forget the name now but i had a flick thru it and saw lots of info on porting pinto heads etc, ive even
found the name of it! its called 'How to power tune FORD SOHC Pinto & Sierra Cosworth DOHC engines for road and track' its by Des
Hammill.
hope this is of some help!
mobile auto-electrical specialists www.hammondauto.co.uk
James
posted on 20/5/03 at 04:43 PM |
http://www.pumaracing.co.uk/pinto.htm
have a very interesting Pinto tuning document.
HTH,
James
