Author: Subject: Westfield Gear Linkage
Furious D
posted on 2/10/06 at 07:57 AM Reply With Quote
Hi all,
I have read on here and Piston Heads that the Westfield Gear linkage is much better than the Tiger one. Having just bought my Tiger i am already having allot of fun but understand that the Westie bit is a much improvement on slick gear changes.
How much should i be looking at paying for one and is the only place to get them direct from Westfield.
D
posted on 2/10/06 at 08:02 AM Reply With Quote
Do you have access to a lathe? Or know someone who does? If so, have a look at the 5-speed gearshift extension on my website.
Click on the "WWW" link below, select "special tools..." from the menu, then click on the gearshift link.
No dimensions, but it's easy to work out with a bit of thought.
If you have the technology it's a very cheap solution, and gives a VERY direct link.
Furious D
posted on 2/10/06 at 08:10 AM Reply With Quote
Thanks for this Dave, i do not have access to a lathe but my brother might have on in his workshop.
D
NS Dev
posted on 2/10/06 at 09:03 AM Reply With Quote
will second that, David's solution (similar to my own) is a MUCH better way of doing the job than the westfield one.
While you're getting bits turned on the lathe, get one of David's rivnut tools made as well, they are excellent, much better then any proprietary tool that I have used (and broken!)
DaveFJ
posted on 2/10/06 at 09:33 AM Reply With Quote
Depends which Tiger gear linkage you have. The original was a couple of pieces of flat steel and the original gear lever cut off with a tab welded on. The 'new' Tiger gear linkage is almost identical to the Westfield item so you would gain nothing through changing it.
The new Tiger linkage has been available for about 3 years now so it is well worth checking before parting with your cash.
Dave
posted on 2/10/06 at 09:46 AM Reply With Quote
Blush...
I should point out that the rivnut tool is my interpretation of a genuine Rivnut item - I just hope they don't notice!
[Edited on 2/10/06 by David Jenkins]
Furious D
posted on 2/10/06 at 09:48 AM Reply With Quote
Thanks Dave, i will have a look tonight and post some pictures, i a pretty sure it is the old one, if that is the case i could just get the new one from Tiger.
D
NS Dev
posted on 2/10/06 at 10:08 AM Reply With Quote
.......but bear in mind that the westfield one is inferior to the "single fork" mechanism that Dave's and my linkages use (among others)
