tom_loughlin
| posted on 24/3/07 at 03:07 PM |
cambelt
I have just changed the gasket on the waterpump (I hope it was the gasket has gone, but I have a feeling it might be the seal, as water is coming from
one of the holes I don't think it should.
(it's a 1.8 waterpump mated to a 2.0 zetec engine)
Anyway, upon fitting the whole lot back together, The cambelt works it's way off... and Whatever I try, it does the same.
Has anyone any idea why idea it does this? Or if I need a new water pump?
The pump is only 400 miles old... so would not be best impressed if it needs replacing already!
Tom
zzr1100rick2
| posted on 24/3/07 at 04:23 PM |
sounds like the bearings have gone in the pump allowing the cam belt pulley to run on the skew throwing the belt off
zetec
| posted on 24/3/07 at 05:07 PM |
Do you mean the cambelt or alternator belt? If you mean the alternator belt then I too suspect the water pump bearing. I had a pump go after 3000
miles, I put it down to too tight on the belt, but then it was a Halfords part so might just have been crap!
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
zetec7
| posted on 24/3/07 at 11:42 PM |
There's definitely something wrong with the water pump or its mount. I suspect there's a noticeable misalignment of the pump's
pulley with the rest of them, causing the belt to "go off the rails". This could be caused by the pump's bearings failing (which
could cause the pulley to cant to one side, giving misalignment), or by the mount itself. If the pump is leaking as well, it sounds like the whole
pump is due for a holiday at the rubbish tip!!
http://www.freewebs.com/zetec7/
