Furious D
| posted on 16/4/07 at 07:20 AM |
Coughing, Splutering and Farting
No not me, the car!
Had my 2.0L Pinto with twin 45's rolling road tuned in Oct/Nov last year. Done about 600 miles since so not allot. Went to the show at Detling
yesterday and it seemed to be coughing, farting and popping from the exhaust allot more than it ever has in the past.
Mainly when you are in say 5th doing 70mph then come off the throttle to slow down but keeping it in 5th. I know that a little farting is OK.
What is the problem? Is it partly to do with the rise in temp?
D
RazMan
| posted on 16/4/07 at 07:45 AM |
On the over-run some unburnt fuel gets through into the exhaust. It can then sometimes ignite if you have a small leak in the exhaust system
somewhere, usually close to the headers.
Woth checking all the joints anyway
Raz
Furious D
| posted on 16/4/07 at 07:47 AM |
I will have a look. Saw your car yesterday at the show didn't i?
The wife was very complementary, you know how hard women are to pleased. She either likes it or doesnt.
D
RazMan
| posted on 16/4/07 at 08:42 AM |
It was indeed - loads of ladies seemed to like it for some reason. I must have been in touch with my femenine side when I built it.
Raz
westcost1
| posted on 16/4/07 at 10:34 AM |
hi
raz man your car looks good lovely finish.
mookaloid
| posted on 16/4/07 at 12:00 PM |
I have had this problem and it is exactly as Raz says - unburnt fuel in the exhaust.
People in cars following would complain about the petrol smell
A little more ignition advance had my car running better, the petrol smell went and so did the banging, popping and farting
mark
Furious D
| posted on 16/4/07 at 12:26 PM |
mark
Cheers mark.
Not having the greatest knowledge, how do i give it a little more ignition advance?
D
RazMan
| posted on 16/4/07 at 05:18 PM |
If you are running an ecu then you can simply reduce the fuel when the throttle is closed but running carbs and a dizzy isn't so easy. I am not
sure that advancing the ignition is such a good idea but it is probably worth checking that you have set it correctly according to the manual.
A mixture check might also be in order if people following you are smelling petrol.
Raz
| posted on 16/4/07 at 06:57 PM |
Just a thought , do you have a point's type distributor? Its possible the points have closed up retarding the timing.
se7ensport
| posted on 16/4/07 at 07:09 PM |
I think you are mistaken, it looks like it cost a fortune, possibly a supercar, thats why women like it: they think the owners minted
