barrie sharp
posted on 27/5/02 at 08:05 PM |
1300 kent +5 speed box
Hi i am fitting a 1300 kent engine into my locost as per the book can any tell me which 5 speed box (type9 or mt75) and what year/cc serria do i get
one from.
thanks
theconrodkid
posted on 27/5/02 at 09:17 PM |
you need type 9, any sierra except t/c and 4wd, reverse is next to first and the casing is iron,the mt75 has reverse next to 4th and an ally case and
is a bit on the big side.
use early 1600 sierra clutch cant remember the diameter but they changed early on in life,you want the small one.
barrie sharp
posted on 28/5/02 at 07:05 PM |
thanks for the info .What does t/c mean? thanks again.
theconrodkid
posted on 28/5/02 at 07:26 PM |
t/c means twin cam,the worst engine ford ever made!
david walker
posted on 28/5/02 at 09:18 PM |
I know of people using the Twincam for Locost builds. I certainly wouldn't consider one myself (mainly due to the size and weight of it) but feel it
unfair and certainly inaccurate to label it as the "worst" engine ever built by Ford. Such dubious honours should go to the V4's, 2.3 V6, Diesel
Yorks and such like.
The twincam is an understressed engine and with sensible servicing will see a good 200,000 miles without rebuild. The timing chains can rattle after
150,000 and if allowed to run low on coolant then head gasket failure will occur, or worse still the head can crack. Otherwise it's a sound engine.
It was developed into the 2.0 16v motor (as used in the Scorpio and Mk 5 RS2000) and later went out to 2300cc. Anyone initially building with a humble
twincam could uprate to this engine without any chassis or gearbox mods (ie straight fit) and would have a car that would kick the ass of any Ford V6
boat anchor (or Rover V8 come to that).
