Author: Subject: zetec coolant temperature sensor
kitcar007kev
posted on 1/5/07 at 06:33 PM Reply With Quote
having probs with 2ltr Zetec temprature dial reading - i have bypassed the fan thermo switch and wired the fan to a switch. if i let the engien temp build up then activate the fan for say 10 seconds the temp drops rapidly but is very very slow to rise again if at all on the temp dial. any ideas?
Andy S
posted on 1/5/07 at 06:42 PM Reply With Quote
Drop topic in google "zetec overcooling" common problem as the piping needs to be carefully connected.
Andrew
kitcar007kev
posted on 1/5/07 at 06:46 PM Reply With Quote
dont think its the pipeing as has been running fine unless somthing has become blocked??
saigonij
posted on 1/5/07 at 06:50 PM Reply With Quote
the common overcooling problem on the zetec is due to the thermostat sticking open.
kitcar007kev
posted on 1/5/07 at 06:54 PM Reply With Quote
me being stupid what picks up the tem to show on the temprature dial?
TangoMan
posted on 1/5/07 at 09:45 PM Reply With Quote
The sender under the top hose outlet (engine end) is for the gauge.
Are you sure that your sender is compatible with your guage.
I only say that because I upgraded from a Pinto and my guage does not match the sender so reads very low.
Summer's here!!!!
kitcar007kev
posted on 2/5/07 at 06:07 AM Reply With Quote
it should be compatible as has been working for around a year untill now.
