oadamo
| posted on 11/5/07 at 05:34 PM |
cam clamp things
hi ive got a zetec 2l. can the cam clamp things be changed from a diffrent head are they a stright fit thanks adam
[Edited on 11/5/07 by oadamo]
| posted on 11/5/07 at 06:31 PM |
Ideally they should not be interchanged from head to head unless they are line bored . It may? ?? be possible to switch them without line boring by
very carefully checking the cams rotate freely as the caps are torqued up
oadamo
| posted on 11/5/07 at 06:54 PM |
only ive been given a head with race valves in and its been ported with some fast road cams in but its had the caps taken off and the guy cant find
them.
and ive just had my zetec engine droped off so i wanted to fit the ported head or do you think i can just change the cams to my engine.
adam
DIY Si
| posted on 11/5/07 at 07:21 PM |
When you say race valves do you mean bigger? If so, it may be worth getting the new head and old cam carriers line bored to ensure they fit correctly.
Sun Tzu, The Art of War
oadamo
| posted on 11/5/07 at 07:38 PM |
the valves are a couple of mm bigger and the valves have been turned down towards the big bit. if you look in the port
there about 5mm in dia
adam
DIY Si
| posted on 11/5/07 at 07:42 PM |
Do you know if you can get oversize cam bearings, or do they run straight on the carriers? If you can get bigger bearings, it may be better to use the
good head and get the carriers over bored a bit. Otherwise you'll only be able to use the cams in your existing engine, as it may not be worth
getting a new head ported and the valves fitted.
paulf
| posted on 11/5/07 at 08:05 PM |
The cams run directly in the head with no bearings , it is highly unlikely that caps from another engine would fit correctly.
It would be possible to have them line bored but would not be cheap.
It would probably be easier to have the seats recut for the larger valves and swap them to the head that is complete.
Paul.
