Author: Subject: Just so I know I'm right
nib1980
posted on 14/5/07 at 01:11 PM Reply With Quote
Following on from my previous thread, I'm convinced i can solve the airlock problem now. But I'd just like to confirm something before i order the sensors and waste alot of money.
I have the followign gauges (thanks Trext7)
Can some confirm the follwoing will be ok as the oil pressure sender for these from ETB I'm convinced the water temp sensor i have is ok, i'm fairtly sure ETB fuel level sensor will be ok too, But will this oil pressure sensor be ok? i.e is it the right fitting for my Cross flow
ETB Oil Pressure Sensor (90 PSI / 6 BAR) - 1/8 th NPTF Thread (includes built-in Low Pressure Warning Light switch) 380 070 250 53
Many thanks in advance
[Edited on 14/5/07 by nib1980]
flak monkey
posted on 14/5/07 at 01:13 PM Reply With Quote
If the oil pressure switch is the same on the xflow as it is on the pinto it will be 1/4 NPT
Sera
http://www.motosera.com
mangogrooveworkshop
posted on 14/5/07 at 01:47 PM Reply With Quote
As far as I remember its only one company as they bought out smiths which was the traditional supplier to catervan. There expert should be able to tell you exacyly what you need. If not tell calvinix and he will get the info for you........
Just tell them what you have and they should advise.
They look like rebranded smiths style.
