caber
posted on 29/5/07 at 06:03 AM |
BIKE CARB HELP
I have acquired a set of carbs from a CB600 and they have a lot of pipes sticking out! on the inlet side there are two biggish pipes at the top and
one 8mm pipe at the bottom that looks as if it is fuel. At the manifold side there are two double connections between the outside carbs tha have a
pipe linking them but nothing on the outside connections. Can anyone help with what all this plumbing should be connected to to work on a Pinto?
TIA
Caber
UncleFista
| posted on 29/5/07 at 06:57 AM |
Basically, apart from the fuel inlet, all the pipes are supposed to connect to the airbox. Conventional wisdom says, leave 'em open to the
atmosphere.
At least that's what I did and it ran great (never went anywhere, just revved it up
I have a manual in PDF format for CBR600 carbs, it's 17Mb but I'm sure I could split it and email it to you..
Edited to say; Ooops, that's assuming you meant CBR
[Edited on 29/5/07 by UncleFista]
Tony Bond / UncleFista
