Author: Subject: RV8 Oil Pump
darrens
posted on 24/8/07 at 02:44 PM Reply With Quote
RV8 Oil Pump
Am I correct in saying that the oil pump is driven by the distributor, so if I remove the distributor I need to find some way of leaving the gear to run the pump.
posted on 24/8/07 at 02:45 PM Reply With Quote
100% correct.
From late 1994, a redesigned timing cover, incorporating an integral crank-driven oil pump was used. So answer is 100% no for those engines.
here is photo of how this can be achieved; the distributor body is machined off and the shaft shortened. I believe there is a bearing fitted at the end - dunno details, nothing to do with me.
[Edited on 24/8/07 by 02GF74]
darrens
posted on 24/8/07 at 02:48 PM Reply With Quote
bonza!!
cheers for quick response
v8kid
posted on 24/8/07 at 03:33 PM Reply With Quote
Another way is to fit the later front cover complete with oil pump. The pump has a much greater capacity and solved a lot of the problems. You also need a pickup pipe and a different sump pan. I think I still have all the bits I used before going to dry sump lying around if you are interested
Fatboy Dave
posted on 24/8/07 at 03:58 PM Reply With Quote
I do believe that the crankshaft is different too. The nose is longer to take count of the fact that the drive key is not present on the dissy equipped engines, so it's not easy to just swap covers without changing the cranks.
Dave
Stop the planet, I want to get off
posted on 24/8/07 at 07:40 PM Reply With Quote
fbd is right; crank is different as it drives the oil pump. not a simple 10 minute job.
v8kid
posted on 24/8/07 at 09:54 PM Reply With Quote
Well it fitted straight on to my bog standard 3.5!
Simon
posted on 24/8/07 at 09:58 PM Reply With Quote
OT
Originally posted by v8kid
......before going to dry sump lying around if you are interested
v8kid,
Could you expand, as I'm sure there's more than me interested What scavenge pump, oil pump, sump etc etc.
Cheers very much.
Simon
