Author: Subject: 7" Sierra Differential
Bacon2002
posted on 9/9/07 at 01:24 PM Reply With Quote
I have a 7.5" Sierra differential (from a 2.0l 1991 XR4i) which unfortunately won't fit my build (GTS Panther).
It looks like I will need to use a 7" Sierra diff.
Does anyone know if I will be able to use my existing bolt on driveshaft and hubs (from the 7.5" differential) with a 7" Sierra diff.
Strange question I know but it is probably cheaper and easier if I can use the original driveshafts and hubs etc.
Thanks,
iiyama
posted on 9/9/07 at 02:18 PM Reply With Quote
Yup, you can. Have to take both of them apart to do it though and swap over the necessary bits. easier said then done!!!
Paul (Notts)
posted on 9/9/07 at 05:08 PM Reply With Quote
I could well be wrong BUT I thought the only size difference between the 7 1/2 inch and 7 inch was the mounting and case at the front. The output flanges are both the same size on the bolt on types and I thought they were same distance apart on both. so shafts should be the same...
Paul
NB as I said I could be wrong....
darrens
posted on 9/9/07 at 06:33 PM Reply With Quote
nay lad, 7 1/2" diff (granada) has larger flanges. The diff width is exactly the same i.e distance between flanges.
I know cos I have one sat in my garage
Bacon2002
posted on 9/9/07 at 07:11 PM Reply With Quote
darrens,
When your next in your garage could you measure the diameter of the flanges on your differential/drive shafts.
That way I can check if my Sierra ones are the same.
Many thanks,
darrens
posted on 9/9/07 at 09:10 PM Reply With Quote
Originally posted by Bacon2002
darrens,
Many thanks,
Rate then, I had forgot a few things, flanges are 108mm (standard LSD sierra being 95mm ish)but have a read of this http://www.locostbuilders.co.uk/viewthread.php?tid=30267&page=&contribmessage=none
specifically page 2
[Edited on 9/9/07 by darrens]
Bacon2002
posted on 9/9/07 at 09:41 PM Reply With Quote
darrens,
That link is really helpful, if not a bit confusing.
I am thinking that since my 7.5" diff has 100mm flanges (and drive shaft flanges) then all I need to do is replace the diff with a 7" one that has 100mm flanges and I should be able to use my existing drive shafts/hubs etc.?
So basically I need a 7" diff with 100mm bolton flanges.
Or am I miss understanding?
Thanks,
darrens
posted on 9/9/07 at 10:49 PM Reply With Quote
darrens,
Thanks,
correct!!
I got a set of half shafts machined with smaller flanges to fit my 7.5" diff and thus fitmy sierra driveshafts (only because I wanted to keep the granada lsd)
cheers
Bacon2002
posted on 10/9/07 at 09:55 AM Reply With Quote
darrens,
Thanks very much for you help.
Much appreciated.
Paul (Notts)
posted on 10/9/07 at 04:43 PM Reply With Quote
darrens
Got a 7 LSD diff in the garage and two 71/2 inc diffs all three have the same size output flanges....................
Paul
