Ratters
| posted on 15/9/07 at 07:58 PM |
ZX9R Needles
Can the needle height be adjusted in these Keihin carbs or not?? I have read that some carbs have a 'circlip' & several grooves.
Thanks.
mackei23b
| posted on 15/9/07 at 08:10 PM |
The standard ones can't be adjusted, you'd need a dynojet kit so that you can adjust the needles with a circlip.
Ian
rj
| posted on 15/9/07 at 08:28 PM |
Its is possible to raise the needles by putting washers under the the top colar, it only takes a couple of minutes to take off the vac diaphram cover
to do this
jacko
| posted on 15/9/07 at 09:17 PM |
As rj says i have two washers under my needles
Jacko
