Author: Subject: XFlow water pump
donut
posted on 28/9/07 at 05:08 PM Reply With Quote
XFlow water pump
How do i know if my kent xflow 1600GT engine has a VISCOS FAN water pump as there is no fan on the engine?
Thanx
dave-69isit
posted on 28/9/07 at 05:12 PM Reply With Quote
viscas fan
viscus screws on to the front off the pump fan bolts on the front with four bolts
paulf
posted on 28/9/07 at 05:14 PM Reply With Quote
Does it realy matter? I assume you will be fitting an electric fan. I did find that my crossflow needed a spacer for the water pump pulley to line up with the crank pulley so that may be the difference if there is one.
Paul.
dave-69isit
posted on 28/9/07 at 05:15 PM Reply With Quote
fan
looking at your piks its not viscus
Fatgadget
posted on 28/9/07 at 05:45 PM Reply With Quote
A viscous fan is attached to the pump by a single left threaded nut/bolt.Normal fans are attached by 4 bolts.
[Edited on 28/9/07 by Fatgadget]
donut
posted on 28/9/07 at 07:03 PM Reply With Quote
Ta!
