Author: Subject: Is the this alternator repairable?
trogdor
posted on 15/10/07 at 07:00 PM Reply With Quote
Hi, i have an alternator that will charge the battery below 3000 rpm, but above 3000 rpm it doesn't work, what could be wrong and is it easy to sort out?
many thanks
tom
mookaloid
posted on 15/10/07 at 07:13 PM Reply With Quote
regulator?
Some are replaceable some aren't
Mark
posted on 15/10/07 at 07:59 PM Reply With Quote
1st step is check the connections at the back of the alternator are clean a tight -- they handle a lot of amps.
2nd Step is check the drive belt is tight enough
3rd Step is check the charging voltage off load and under load
However if the connections are sound most likely the alternator regulator is knackered -- how easy to fix depends on the type Lucas-Magnetti Marelli ones area a dawdle if you can get the parts,
trogdor
posted on 15/10/07 at 08:54 PM Reply With Quote
its from a v6 mondeo ST24 engine, hopefully the regulator is replaceable?
