Snuggs
| posted on 10/11/07 at 09:40 PM |
MegaJolt
Does anyone know the optimum distance between the trigger wheel and the VR sensor.
I currently have it set to 0.8mm and is runs but every now and again I get no spark for a fraction of a second.
The bracket is fairly sturdy but could it be vibrating and closing the gap.
Also I am still looking for a V8 Rover map.
Clive
http://www.topcashback.co.uk/ref/snuggstcb
Spider pig, spider pig, does whatever a spider pig does.
I doubt therefore I may be.
Luposlipophobia : Fear of being chased by wolves around a freshly waxed kitchen floor, while wearing only socks on your feet.
My mind not only wanders, sometimes it leaves completely!
http://www.venganza.org
http://www.jesusandmo.net/
http://www.snuggs.co.uk
paulf
| posted on 10/11/07 at 09:50 PM |
As close as possible without it rubbing, but in practice 1 to 1.5mm is fine..The bracket does need to be as sturdy as possible though. It is also
important to use resistor plugs and decent leads as well as sheilded canle for cranksensor, pip, saw and tps leads to prevent any interference being
picked up .
Paul.
Marlon
| posted on 10/11/07 at 09:53 PM |
I could be wrong but I thought that it was around 3mm max(about what mine is).
john.
Band Anyone?
Linky to SWMBO 's band
Linky to Brother in laws band
MKoc 1081
triumphdave
| posted on 11/11/07 at 01:45 PM |
Mines set at 1mm runs fine.
| posted on 11/11/07 at 02:17 PM |
Somewhere around 1mm is fine - close enough to get a good signal, but far enough away to avoid any collisions.
The mount needs to be really rigid - it's not uncommon to get it vibrating at certain engine revs, which upsets the signals and the ignition
timing. Massive is good!
DarrenW
| posted on 12/11/07 at 09:07 AM |
Clive,
Have you tried putting a post on Autosportlabs for the map? Theres bound to be someone on there with one to get you started.
Ref sensor - agree with above ref bracket. My MJLJ kit came with wiring loom and ive had no isses with that so assume it must be well shielded. id
guess you would have got yours right.
Jenko
| posted on 12/11/07 at 12:11 PM |
1-3mm is fine......
Sounds like you have something else wrong....
Check the Cable to the VR sensor is screened, and the screen is grounded (very important)....If this still does not work, then it's time to
question the sensor....Also as mentioned, make sur the bracket is not vibrating, and touchin the toothed wheel.
| posted on 12/11/07 at 12:36 PM |
Yes - the screen should be grounded, but only at one end. If you ground both ends you will be prone to 'hum loops' - the loop acts like
an aerial (this is in the MJ installation instructions).
In my car, the only earthing happens at the EDIS connector - all earths are commoned, with one wire going to chassis. The MJ and coil earths go to
the same point.
HTH
Snuggs
| posted on 13/11/07 at 10:32 PM |
Thanks for all the replies guys.
I have not had a chance to look at it yet.
Clive
