Author: Subject: Type 9 1st to 2nd change
ditchlewis
posted on 28/1/08 at 01:13 PM Reply With Quote
I was out for a drive on Saturday afternoon and I tried to pull on to the A12. I put the car in 1st and launched it… when I tried for 2nd it just would not go into gear, in after a second or two I just put it in third and floored it…Thank god for a light powerful car, and I was soon pulling away from all other traffic.
This problem only occurs when I try and change gears very fast.
Is this a common problem ie it’s a slow old box?
It syncro is getting tired – there is no grinding?
It would be better if I started in second as first is too low?
it performs normally when being treated with some respect but it has happened twice now at the same junction when I try for a fast change.
are there any common problems or downsides to the type 9?
Any ideas of or is it just my bad driving.
Ditch
Mole
posted on 28/1/08 at 01:18 PM Reply With Quote
I read somewhere (not sure where) that type 9's don't like quick changes. Someone else will need to clarify though.
ditchlewis
posted on 28/1/08 at 01:21 PM Reply With Quote
Thought it might be i'm just going to have to try and be a little more sympathetic with it...... NAH
ditch
posted on 28/1/08 at 01:27 PM Reply With Quote
It's cause its a long way from 1st to 2nd and if the gear sticks too short... well, get my drift?
ditchlewis
posted on 28/1/08 at 01:31 PM Reply With Quote
Oh does length matter then
i did cut it short so it would fit under the dash
and first is a bit of a stretch.
ditch
[Edited on 28/1/08 by ditchlewis]
posted on 28/1/08 at 01:47 PM Reply With Quote
I have the same issue....
http://www.locostbuilders.co.uk/viewthread.php?tid=70835
...I did check the oil level which was OK, but didn't bother changing it.
After nearly 3k miles I have got used to it and can usually get a clean shift reasonably quickly. Pulling off in 2nd also helps greatly and IMHO doesn't do your outright acceleration any harm either by skipping a gear change particularly in the damp/wet.
[Edited on 28/1/08 by nick205]
ditchlewis
posted on 28/1/08 at 01:56 PM Reply With Quote
i'm glad i'm not the only one
i do find i get a lot of wheel spin when i use 1st prehaps just using 2nd would be best
ditch
dan__wright
posted on 28/1/08 at 02:23 PM Reply With Quote
perfect excuse to go BEC
*hides*
FREE THE ROADSTER ONE…!!
skippad
posted on 28/1/08 at 02:34 PM Reply With Quote
The best upgrade i did to my indy was to get a TransX straight cut close ratio box with a long first gear.
First gear is 2.25 which is good for nearly 60mph, and the other ratios are just in the right 'zone'.
Fitted with a quaiffe quick shift, makes a very positive short gearchanges.
whitestu
posted on 28/1/08 at 03:15 PM Reply With Quote
Mine's fine - haven't caught it out yet.
Stu
posted on 28/1/08 at 03:22 PM Reply With Quote
*hides*
Usual BEC hijack!
Can we start a poll?
1. How many BEC gearboxes have fallen to bits?
Answers on an A3 piece of paper please.
2. How many car gearboxes have given up the ghost?
Answers on a postage stamp please.
[Edited on 28/1/08 by coozer]
whitestu
posted on 28/1/08 at 04:48 PM Reply With Quote
The BEC boys are quite used to pushing their cars backwards so pushing forwards when the gearbox explodes shouldn't be too hard!
Having said that I suspect I'd have one given half a chance!
posted on 28/1/08 at 06:42 PM Reply With Quote
Use semi synthetic gear oil , it will improve the gear change no end. BGH Gear tech don't recommend a quick shift with a type 9 due to weak baulk rings/synchros. If you think it may be the box I will have one for sale shortly when I fit my BGH box
posted on 28/1/08 at 07:12 PM Reply With Quote
When mine went notchy the three bolts holding the gearlever on had come loose.
ditchlewis
posted on 29/1/08 at 09:05 AM Reply With Quote
i will check the bolts
generally it is not notchey, but it can be beaten. i will just have to take things slower
ditch
