dnmalc
| posted on 28/4/08 at 09:53 PM |
Pinto Dizzy
I have a 1600 pinto with a points type dizzy. I have bought a pinto electronic dizzy to replace it but on offering it up it seems to be different and
it does not go in fully. Are these interchangeable or have I missed something ?
Paul TigerB6
| posted on 28/4/08 at 09:59 PM |
You sure it isnt just that it hasnt meshed properly with the oil pump drive and distributor drive on the crank?? Might need to give it a little wiggle
around (ooo-errr missus  ) to get it to engage.
[Edited on 28/4/08 by Paul TigerB6]
mookaloid
| posted on 28/4/08 at 10:07 PM |
As above
jabbahutt
| posted on 29/4/08 at 02:17 PM |
I did the opposite and replaced an electronic dizzy with a points based. It should slide in, as above it may need a wiggle to ensure it meshes with
the aux shaft correctly.
hope that helps.
Nigel
| posted on 29/4/08 at 07:04 PM |
Is it locating on the oil pump drive?
dnmalc
| posted on 1/5/08 at 05:34 AM |
Have checked again it is not engagement but it seems that the ground section of the spindle is interferring with the small bore at the bottom. so I
gues its a tolerance issue
