Author: Subject: Radiator Leak
sh0cked
posted on 20/6/08 at 07:14 PM Reply With Quote
Radiator Leak
Ello guys,
Basically im having a problem with my locost Indy, I've built it up with a Fireblade engine and now ive discovered that when the engine comes up to temp its causing the radiator cap to wee water everywhere.
Im getting a bit tired of topping the thing back up with a new bottle of water constantly. So do any of you have any ideas what might be causing this OR how to resolve it?
sh0cked
posted on 20/6/08 at 07:28 PM Reply With Quote
22 views and no replys?!
posted on 20/6/08 at 07:33 PM Reply With Quote
abit like this http://www.locostbuilders.co.uk/viewthread.php?tid=91677
NS Dev
well, for a start check the rad cap is ok, it could be that the spring is broken etc and that's causing it.
then make sure there are no airlocks in the system
then is it only when it is hot, or does it throw water out when still fairly cold, but revved hard, in which case its probably head gasket
stuart_g
posted on 20/6/08 at 07:34 PM Reply With Quote
Is you're header tank at the highest point in the system?
austin man
posted on 20/6/08 at 09:15 PM Reply With Quote
you may need a rad cap with a different pressure setting, I had a similar problem on my old aus#tin all down to pressure rating
sh0cked
posted on 20/6/08 at 10:12 PM Reply With Quote
It only does it when the Engine is hot, never at cold! My header tank is the highest point in the system (had to adjust that) and I was thinking it could be the Rad cap not having a strong enough pressure seal rating?
NeilP
posted on 20/6/08 at 10:17 PM Reply With Quote
If your header tank has a pressure release valve (if it's yellow then it does) then get a non-releasing cap for the rad from CBS for about a £5 - job done!...
If you pay peanuts...
Mentale, yar? Yar, mentale!
Drive it like you stole it!
posted on 21/6/08 at 08:37 AM Reply With Quote
Cooling systems should only have one pressure cap -- otherwise it can cause air locks and/or excessive coolant loss on warm up.
The pressure cap is a 2 way valve it acts as a vacuum relife valve allowing air back into the system as the engine cools.
