Author: Subject: Fireblade drive shaft flange
LBMEFM
posted on 4/7/08 at 12:59 PM Reply With Quote
Sprocket now off and flange ready to bolt on with a spacer. Once in place and tightened up the problem I can see is how do you stop the prop shaft bolts from turning when you do the nuts up. The bolt heads are inside the casing.
Barry
Howlor
posted on 4/7/08 at 01:25 PM Reply With Quote
I think mine was tapped so no nuts.
ReMan
posted on 4/7/08 at 01:32 PM Reply With Quote
I fitted the bolts from the outside and nuts on the inside.
Whatever though I have room behind it to get a spanner on the nuts......
Could it be fitted either way round?
Also I hav a substantial washer behind it to ensure the bolt tightens against the adaptor, they do vary.
[Edited on 4/7/08 by ReMan]
